Alright guys,just a quick question,finally getting round to fitting my defi gauges tomorrow,just wanted to know if anyone had any advice on the best way of holding them in position,I have bought 2 60mm gauges one I am fitting in the centre of the dash where I have a vent face missing,and the other I want to fit in the original boost gauge position,I have seen a few fittied directly onto the front of the a pillar gauge pod, do you just use double sided tape or something a little stronger? And do you need to adapt it to fit the 60 mm gauge at all? I have seen the thread about fitting a gauge in the original position behind the plastic but I don't like how that looks....
Also when fitting the. Boost gauge can I just remove the t piece that's in the hose already leading off to a little box on the suspension turret, and just plug in there or do I need to cut it and place it further down? I am assuming the t piece already there is to give readings for the standard gauge??
