How to adjust clutch pedal?
dss15
Hey does anyone have a good guide for adjusting the clutch pedal.
ordered a new clutch - christmas time, unlikely to arrive for a bit, want to see if i can get the current one to engage better.
Makes clicking noises on takeoff, i'm assuming teeth -- shudders.. gone basically.
Also, for those interested, if your steering rack makes any noise whatsoever, jack the car up and check ALL bolts - found 2 loose, shaken loose by hard suspension over time no doubt. Mechanics couldn't find the problem, mostly because they were lazy i'd say!
I degreased everything, high pressure cleaned it so I could see, then re-lubricated everything. Makes me feel a lot safer knowing everything is tight clean & lubed heheh
