Memory refresher needed - fuel lines...
elizium
Moscow, Russian Federation
www.mys15.org
All
unfortunately my memory is not as good as I hoped and the text I put on my labels has faded... need a quick bit of input
At the bottom of the engine bay close to the firewall are the two fuel hard pipes - one has an almost 90 deg bend in it, the other closer to 45 deg.
I'm currently redoing the fuel system with upgraded aeromotive FPR, filter and hoses but can't for the life of me remember which one is the feed and which is the return.
can someone bring some light to the dark corners of my mind? :)
thanks
Chris
martinbattye
the one with the 45deg bend is the return on s14a..
90 up to the filter..
put two pipes on into bucket keyon. and get a mate to watch..
elizium
www.mys15.org
Brilliant - actually it was kind of what I remembered good to be sure. As for putting the key in - we're not quite up for that yet as the ECU and harness isn't fully installed yet... guess I could just put 12V across the fuel pump wires though.:)
cheers
Chris
