Need Help With The OEM Oil Pressure Gauge!!!!
C
chupiplum
Can anyone help on how to change the light bulb on the OEM Oil Pressure Gauge??? mine stoped working
pull it out, change the bulb............... its a replaceable part
if you look in the useful section thread you will see a detailed description on how to get to this referring to the boost gauge, same process same holder
7 February 2010
Cork, Ireland
www.crossbarryprecision.com
Instead of starting a new thread, i said i would ask here. My oil gauge light recently blew and I took it out but i have never seen such a small bulb.
Can anyone give me the bulb type name and is it easily got?
Cheers
23 September 2014
Maryland
Part Number:24860-88F00
Description:SOCKET & BULB ASSY
This is old but hope this helps. It is for the boost gauge but I believe they are the same bulb.Also, the US doesnt carry this part so I went to Honda/Acura and used one of their small TS bulbs. It was a bit smaller bulb but had the same base and watage. It lights up just fine at night as well...too bad it cost me $10USD
23 September 2014
Maryland
There are only two screws once the gauge is out of the pillar. Its a simple quarter turn to remove the bulb
