F
finch
Hi All,
I own a S15 Silvia imported from Japan. I bought it with a bad clutch, first it slipped on the high gears then on all the gears. I ordered a new Ogura 409 for the my Silvia. After some hard time replacing the clutch, I managed to fit every thing as it was and went to start up the engine to verify my work. These are the problems I had immediately on the first start up after the clutch replacement:
Squeaking/rattling noise, apparently coming from the clutch, then it stops after a few seconds.
Squeaking/rattling noise when I press the clutch pedal.
Can some one please point out to what may be wrong? Also is it ok to use the standard clutch slave cylinder with this new clutch?
Thank you very much guys.
