Oil Pressure Sender
5 May 2010
UK
Is it the same for the R33 GTST as for the S15?
Thanks v muchly Sam
tooley
When only sideways will do!
10 October 2009
West Midlands / South Wales
What do you mean? a sender is a sender. The only different thing would be the sandwitch plate that it bolts to. I think all the nissan oil filter housings are common. so i would say yea.
Yep the sender is the unit that will convert the heat temps measured into electronic signals so one end goes into the BSPT port (if British made sandwich plate), the other end will plug into whatever unit is designed to output the electronic signals on the display :)
