Part Number Help: Wiring Harness :(
elizium
Moscow, Russian Federation
www.mys15.org
Hi all..
having an issue trying to work out in FAST what the part number is for the sub harness for the ignition coils is.
I have attached an image from the service manual.. basically I need the one that has the connectors 101-106 on it. FAST isn't very clear on the major numbers.
I already have the sub harness for the injectors (24075-85F00), the main harness (24011-85F00) and the battery +ve harness (24077-85F00)... just can't for the life of me suss out which one is for the coil packs.
Anyone with a clue - please help :)
Cheers
Chris
elizium
www.mys15.org
OK .. found it... it wasn't on section 240... that is why it was hidden :)
Part number - for reference in case anyone else needs it in future is: 24079-91F00.
With the part numbers above you should have all the wiring harnesses you need to connect the ECU to the engine... :)
