R32 GTR caliper & coilover clearance
Has anyone got R32 GTR or R33 turbo calipers on the front of there car? if so do your wheels clear? the 17s my car came with clear, but i wanted to keep the 18's that were on my spec s,The 18's they clear using a 6mm spacer, but we have to go and fork out $400 every time you need to certify something in NZ.
Has anyone else got 18's that clear? if so what type and offset?
It depends on the wheel spokes and how they are shaped. I am running 19's (I know, they are not 18") and a 3mm spacer with standard calipers. Once I fit the R32 GTR calipers I will be able to do without the spacer all together. My wheels are Lenso DC5's. I think my offsets are +35 or possibly +45, I can't remember.
_Wing_
24 August 2006
Yeah all depends on the spoke design and offset of the rim in question. The GTR32 calipers clear the standard 16" rim and also the space saver spare :D so you can test with that
Im also running the GTR disk, it clears using a 3mm spacer, just, but the space saver has no chance in hell of fitting, i would have to have about 30mm for it to clear.
I just measured the disks the are 310mm x 30mm ?? what nissan disk is 310 give or take a mm either way, R34??
just went to pull the fuel pump out to put my walbro in, discovered a GTR fuel pump already there..
310mm sounds like an R34 disk. the R33's and R32GTR were 296mm. The standards S15's are 280mm.
