Q
quicsilvia
Hey all, I'm having some electrical issues with a 99' Spec R and not too sure of the cause. When the ignition is switched on I will get a buzzing noise from the kick panel which I'm assuming is a relay which I'm not sure is relevant to the following issues. 1. When the door is opened and key in the ignition the typical chime isn't heard and the dome light isn't turning on(switch set on the middle setting) and 2. The radio settings, A/C control settings and clock on the cluster will not retain memory. I know all of those get constant power so obviously they are not when the ignition is switched off. My question is what is the cause of this, relay, some sort or control unit ect.??
