Spacers
14 April 2012
Northampton
As I want a bit of poke with the wheels being out from the car, does it matter what spacers I put on the hubs? Arches will be rolled, wheels are 18x9.5 et25 fronts and 18x10 et35 rears, ive been advised that id need 10mm spacers all round (fronts to clear coilovers, rears just to match) could i put on a 25mm spacers on all round to make them go outbound a bit more? what would it affect?
29 April 2012
Aberdeen
if you choose to space out your wheels out by 10mm you need to get extended studs and open ended steel wheel nuts or risk having the threads strip. there won't be enough thread from oem studs to engage the nut with 10mm spacers.
20mm bolt ons will be fine but you need to consider offset and roll arches accordingly or fit over fenders
i would test fit with 10mm spacers first and see how it sits the decide what needs done
