Speedo Conversion, Where to take the live from?
16 August 2016
Hertfordshire
Hi guys,
Currently in the middle of changing the speedo from KPH to MPH, I've soldered in the signal feed and the converter but where should I take the live feed from and ground? Is there anything on the same loom that can be used? I did see a driftworks post of someone saying that there and positive and negative terminals on the back of the actual instrument cluster but I cant seem to see them.
Cheers
7 March 2015
London
Just commenting to follow.
Did read something about this before but i stole power from the fusebox and run the wire up, not how I would like it permanently but it did the job
Joeh
12 December 2006
London
www.silivaoc.com
@silviaownersclub
Worst case the radio is not far, you can take it from there. Normally I would search by using a multimeter and check a few wires one by one with the ignition off and on. Usually positive on Japanese cars is a yellow wire with a red line.
Hope that helps
immy21
9 November 2012
Edinburgh
Use a multimeter or test light to find ign 12v
That's what I done, same plug as signal wire but can't remember which wire it was.
