Speedo not working. Please help
30 September 2016
Newquay
As it say above my speedo not working. We have checked what we could but all seems to be plugged in. Any ideas will be appreciated. Thank you
Sent from my SM-G920F using Tapatalk
Joeh
12 December 2006
London
www.silivaoc.com
@silviaownersclub
I have a spare dash cluster you're welcome to try if you get stuck, the only thing is that the RPM doesn't work on it
Generally it's either the speed sensor or the dash that fails, not sure if there are any fuses relating to the gauge either.
The best way to confirm would be to read the live data from the ECU to see if any speed is being registered, if there is then it's most likely the dash.
19 September 2020
Essex
Ressurecting this thread Joeh, I have the same issue at the moment. I'm trying to work out whether it's the cluster or the sensor, the cluster seems to test ok in it's diagnostic mode, and I also seem to have a signal coming from the sensor/abs controller (but haven't tested with a consult machine)
There's no fault codes at all (tested using the paperclip method with instructions from here), anything you can suggest to try?
Joeh
12 December 2006
London
www.silivaoc.com
@silviaownersclub
I also had the same thing and in the end it was actually the cluster unfortunately, however I'm not suggesting it would be the same in your situation
Have you tested the A/C voltage from your cluster side where the signal comes in or was this a test at a different location?
19 September 2020
Essex
Cheers for the reply, yeah there is voltage getting to the cluster. Begining to agree with the cluster thought, it's like it's not sending a speed back to the ECU.
Looks like my hand is forced on a nismo cluster and hope that's the issue 😅
