SuperPro Bushes now available
MWTech
31 August 2010
Near Knockhill
hey guys
im pleased to be able to offer these to the forum
Many different kits are available from single sections of the car, front of the car, rear of the car, and full car kits
Im sure some of you will have experience with these and im sure a lot of you will know who SuperPro are :)
HIGH-PERFORMANCE polyurethane suspension bushes
SuperPro bushes are tried, tested and proven in motorsport, which means they deliver outstanding performance. Their innovative design and superior materials offer dramatic improvements in handling and give a more precise feel through the corners.
Unlike some polyurethane bushes, with SuperPro products there is no increase in vibration or ride harshness, an attribute that makes them an ideal choice for cars that are used for both normal road driving and track days.
• Improved handling and stability
• Long life, low maintenance
• Precision engineered for an exact fit
• Increased tyre and suspension life
• No increase in vibration and road noise
SuperPro manufacture a wide range of bushes and kits to fit most Japanese cars
including: Mitsubishi, Subaru, Toyota, Honda, Nissan, Mazda and Suzuki.
All bushes come with SuperPro’s unique three-year / 36,000-mile guarantee.
Since there are so many different areas SuperPro covers, please get in touch
but to give the forum an example. the SuperPro kit which covers the full car which retails at £385 including vat...
I am pleased to be able to offer this to the s15oc for £340
Sounds like a good price mate, is that this kit?SuperPro Handling Enhancement Kit S14/S15
$529.00 *$476.10
This kit contains 36 bushings, 20 inner tubes, 2 outer shells, and consists of the following:
SPF1483K x1 (front control arm lower-inner bushings)
SPF1202K x1 (caster rod bushes)
SPF1750K x1 (rear control arm lower-inner bushings)
SPF2296K x1 (rear control arm toe adjusting)
SPF1638K x2 (rear control arm upper-inner / outer kit)
If so this is the kit I was looking to buy soon...
MWTech
31 August 2010
Near Knockhill
no that kit is a different one, the kit mentioned above includes more
it includes
1xSPF1009K ( Control Arm Lower - Inner Bush )
1xSPF1202K ( caster rod bushes )
1xSPF2551K ( Steering Rack & Pinnion Mount - Power )
1x SPF2092B-4K ( Sway Bar Link Bush Kit )
1xSPF1484-27K ( front Sway Bar Mount To Chassis Bush )
1xSPF1750K ( rear control arm lower-inner bushings )
1xSPF2296K ( rear control arm toe adjusting )
2xSPF1638K ( rear control arm upper-inner / outer kit )
1xSPF2667K ( rear Sway Bar Link Bush Kit )
1xSPF1485-20K ( rear Sway Bar Mount To Chassis Bush )
the kit you are after retails at £334 including vat. applying s15oc discount, your price would be £295 :)
In which case I may as well go for the kit you are offering as I need steering rack bushes anyways and was gonna be charged £40 for poly bushes for that so would work out the same cost but have more in the kit,if I can get the cash together in the next couple of weeks I will be in touch mate,seems like a really good offer to me!
How much would I be looking for postage matey?
Yeah I will be in touch soon,got my mot in nov so really wanna get them before then,I will be in touch soon mate,thanks for your help!
Your telling me,both my car insurances due with in a month and looks like I may have close to 1k to spend on this one,bad times!!
Hopefully will be able to afford the whole kit ,if not may just have to get specific bits for now,but as I said will let u know as soon as I do mate!
MWTech
31 August 2010
Near Knockhill
everything for the rear is listed as follows -
Control Arm Rear - Lower - Toe Adj Arm
Control Arm Upper - Inner / Outer Bush
Control Arm Upper - Inner/Outer Eccentric
Cross-member Supplement Washers
Differential Pin Mount Bushing
Roll Centre Adjusting Ball Joint Kit
Radius Arm Upper - Inner / Outer Bush
Cross-member insert enhancement mounts
