Hi,
I have been experiencing car stalling problems recently.
at slightly higher speeds, i clutch in, the revs drop below idle revs and sometimes just stalls.
Revs are now adjusted to idle higher at 1000revs.
I changed a new blow off. I have cleaned up the pipes.
But still this problem exists, abiet not so frequent. Then someone raised to me
that i may need to mod the tps if i have changed my throttle body. I am using the naprec 70 or 80mm(cannot remember) throttle body. Does anyone have this and do you know if need mod the tps?
idle can occasional be rough and jumps between 900-1200.
I have a idle control valve and a stock tps on standby. not sure if anyone can share if u have the same throttle body as mine or experience the same problems.
