Turbo flutter
25 June 2014
Prince George British Columbia
First of all, Hello from British Columbia Canada, first time posting here.
Secondly i searched before posting so i apologize if there was a post previously and i missed it.
So i was wondering if you guys and or girls have used a Greddy RZ bov before and if you ran into turbo flutter from using it. Mine is plumbed to recirculate and im pulling about 12 lbs of boost. Ive done the single spring mod and have the weaker spring installed right now and have fully released the adjustment screw. Still getting flutter.
Does anyone have any suggestions? Thank you in advance.
24 January 2013
Kent
Delete and go for full flutter :) I'm running no bov on mine and have no problems. But on a serious note maybe make sure that it's plumbed in properly as it may not be registering the correct boost level so when it should dump it won't as it thinks the boost is not high enough
25 June 2014
Hmm. Im 99% positive its plumbed correctly.
And lol i dont really care for the turbo flutter. I enjoy the normal air release noise more personally lol. To each their own.
sibbers
11 February 2015
Twickenham
A little bit of flutter is normal unless you silence the air filter (assuming you don't have standard air box)
sibbers
11 February 2015
Twickenham
But the dump valve is also going too, yeah? I'd expect to have both pssshhht at gear change (you have to imagine the sound effects heh) and flutter with a mushroom filter, but if you're only getting flutter then I guess the BOV isn't plumbed in right? But it sounds like it is from your description. I really like the flutter sound tbh I bet id love it :) soz I'm not more helpful buddy!
25 June 2014
Haha its all good thanks for trying at least
20 June 2014
Merseyside
I'm thinking of removing my BOV but scared incase it ruins the cat, not sure if that's a myth though, hah!
