I no it's in the fuse board in the drivers side footwell but anybody no what relay it is? Need to change it, my cars of the road till I can find it,cheers
i found it its drivers side,up behind the speedo almost,well not that high but nearly, i changed all the bulbs to LED and the orginal relay will fault if u do that so changed the relay and now its working,so have led indicator bulbs and so on:nod:
What relay did you use mate as I was going to convert to LED's but couldnt be bothered with the hassle associated with them flashing double speed! If it just needs the relay changing then i would do it.
Its just a relay, basically i done the same with my 2002 civic type r, i changed all the bulbs to led from ultraleds.com and on there they sold a relay for it aswel. i kept all of these bulbs and the relay and they fit the s15 apart from the relay....i put spade connectors on to make it fit. All seems fine so far sorry for late reply
