Will a abs s13 vlsd pumpkin be a straight bolt in on my s15 spec s non turbo
no the front bolt holes are different size, and the rear bolts are 4bolt instead of 2bold you can get around it easy enough though, just pull the head out of the diff and put it into your S15 open diff, providing its not the R180diff and is the R200 diff head (the diameter of the crown wheel) it will go in fine just dont cock up the placement of the shims when swapping the head over and you are away. Or just pull your S15 open diff and weld that thing up slam it back in.......OPEN diff to NO SLIP DIFF..... ever
