FMIC battery fixing
henrico
14 June 2009
Surrey
Hi,
Just fitting my Apex Type 1 intercooler and have drilled the hole in the battery tray and swivelled the battery around but not sure on how to fix it back on again. Will I need to drill any holes to fix it in again?
Thankyou :wave:
henrico
14 June 2009
Surrey
Erm, it's the one supplied by Apex with the terminals swapped so positive is near the fuse box..
5 November 2008
Hertfordshire
I have used a different battery so not 100% sure have a look at what othe people have done.
Can you not use the same sort of setup as standard but obviously move it to suit?
9 November 2009
South West
I had to carefully bend part of the original battery tray, so the battery could be moved further to the left - to allow for the intercooler pipework.
You can re-use your standard Nissan battery fix down items (the strap and long bar with thread at one end), but I had to make an extra bar to hold down the other side and drill a hole to suit
Hope that helps and makes some kind of sense
henrico
14 June 2009
Surrey
Yeah thanks, my mate's going to be helping and he is good with tools and such so I'll tell him what you said and hopefully we can bodge something together ;)
