S15 Power Windows Dont Go Up/Down
8 May 2022
Sydney
Hi all,
I have an ADM and JDM S15. Windows were working fine in both cars, but my ADM one drivers side was a bit slow.
Anyways, I swapped the door cards from my ADM to JDM as the ADM has been retrimmed nicely, thinking I could do so without changing the switches from the ADM to the JDM.
After the swap, the windows for my JDM car didnt work. I looked in my fuse box and I popped the power window fuse. So I changed it for a new one and still no luck.
Then, I reverted everything back (Original JDM doorcard and switches to JDM car, Original ADM doorcard and switches to ADM car), and then my drivers side ADM window also didnt go up/down.
So now 3 windows between 2 cars are stuffed. Just wondering what it could be? Is there a RELAY for power windows, or only a fuse?
Any help would be appreciated, thank you.
31 December 2023
Victoria
www.youtube.com
@auditt3.6
Sounds like the plugs might no be seated properly and no longer making proper contact with the pins in the switches side.
So check the plugs are pushed on all the way otherwise check there's power going to the switches with a multimeter.
