Never wanted to have to do this.. But I'm going to have to part with my Spec R Silvia.
1999 Nissan Silvia S15 Spec R - 6SPD Manual
(imported completely standard & mint condition in November 2009)
Pearl White with complete and factory fitted aero kit, HIDs as standard.
Taxed till May, MOT'd till Nov.
ENGINE TUNING
Apexi filter
Stainless turbo elbow
Spec R BB Turbo
3" downpipe & decat
Blitz NurSpec R catback
Front mounted intercooler
Braided oil & water lines
Walbro fuel pump
Iridium plugs
Greddy ProfecB Boost controller set at 0.9bar
MISSION & FOOTWORK
Tomei 2way LSD (3.9 final drive)
Driftworks front solid LSD mounts (brand new)
Driftworks poly gearbox mount (brand new)
Cusco engine mounts (brand new)
Tein tie rods and ends
Daiyama Coilovers
Adjustable tension rods
Adjustable toe, camber, traction rods
Subframe locking collars
Grooved brake discs
INTERIOR & SECURITY
Nardi Torino 350mm deep corn steering wheel and HKB boss (brand new)
Bride Zeta II bucket seat on low Recaro rail
TRS Magnum 4 point harness (brand new)
Blitz shift knob with custom Leather Gaiter
Depo racing gauges (boost, oil temp + pressure, water temp (brand new)
Kenwood headunit
CAT1 Thatcham Approved alarm with turbo timer built in.
ADDITIONAL
Nismo smoked side repeaters
Carbon fiber slam panel
Relocated wiring loom above drivers wheel arch for clearance
WHEELS
Front ROTA GTR 18x9.5 ET+30 & 20mm spacer with 225/40/18 Nexen's
Rear ROTA GTR 18x9.5 ET+30 with 255/35/18 Bridgestone Potenza SO3's
Just a couple of bad points to the car - Electric windows don't work (been told its the door switch or relay) & Central locking fob needs a new battery. The car has been drifted so has a few small marks here and there.
Apart from those the car is absolutly savage to drive and has all the basics covered. Everything is tight and responsive! It's also had a new wheel alignment done 4 days ago to Mitto spec.
Located in Kettering, Northamptonshire.
£7800
ENGINE TUNING
Apexi filter
Spec R BB Turbo
3" downpipe & decat
Walbro fuel pump
Iridium plugs
MISSION & FOOTWORK
Daiyama Coilovers
Grooved brake discs
INTERIOR & SECURITY
Kenwood headunit
ADDITIONAL
WHEELS
£7800
