Sr20vet queries?
Sair
28 December 2010
Northampton
Hi everyone i need a knowledge on sr20vet...
Because i was thinking to change to sr20vet from sr20det other than mazworx conversion kit i am not knowledgeable to sr20vet. Checked many forums regarding vet but not satisfied on my queries... and yes i am trying to swap p12 primera sr20ve head if x-trail sr20vet head has more potential then definitely change my mind well my questions are
1, can i use same sr20det wiring ,sr20det power fc and cam angle sensor
2, are p11 head and p12 are same (i mean there rocker cover are interchangeable)
3,exaust manifold will be same of sr20det
4,xtrail sr20vet is good or primera sr20ve is good?
willy s15
25 January 2014
greece athens
hey sair
you have to use power fc ecu now about cam angle you can only use from primera or xtrail cas nothing else
the p11 head is more easy to find one and the other is the part you have to change it is more cheaper than p12
is not the same has a few things is nothing important to worry
yes you can use the same but for better resolute bigger is better
primera and xtrail is almost the same head
primera p12 head is a quite rare has 204ps
xtrail t30 head is very rare and very expensive to find one has 280ps
in my opinion and you are ready to do this conversion go for p11 head (( almera ))
if you go for 500ps + you have to change a few things in the head ( valve springs cams solivoids
if you need more i am here :)
Sair
28 December 2010
Northampton
hey sair
Mate just bit clear your message box
Sair
28 December 2010
Northampton
All cleared mate
