Well, I’m selling my highly modified S15 to import a more standard one from Torque GT.
Ironically, I’m bored of mine. Not driving it, because that IS awesome. But I like seeing progression with my cars, from standard and making it my own (I want to make a full build thread). I miss saving up for parts and fitting them myself.
This is already done up, so all I can really do to it is wash it a lot!
There’s a build thread on the site (will link when I get home) from when Ray owned it and not much has changed since.
The Z32 maf was taken off at some stage and I don’t think it was remapped after this, so air / fuel is a bit up and down. The idle fluctuates on start up for 10 seconds and then sits fine. Hopefully fitting the Z32 and mapping again will sort this and get the power back. (Next couple of months)
I’ve also got refurbished lower control arms and new bushes to fit from Slide Motorsport, as they knock slightly (Fitting next few weeks)
Bought for 16k and spent over a grand since buying it in January. Oil filter relocated. All new oils. Fuel filter replaced. Then the above items to fit and map.
I’m looking for 15,500 with everything done. Or 15,000 how it is (can discuss prices on the parts, or I’ll throw them in)
Absolutely no rush to sell as I still love the car. But would like it gone in the next few months to have a bit of fun in the new one before it goes back to raining every day!
HKS super sqv bov with recirc kit
Hks fuel pressure regulator
HKS GT-RS ported turbo kit
HKS adjustable actuator
HKS EVC VI boost controller
HKS intake hard pipe
Densp iridium sparks
Sard 850cc injectors (screw m5x0.8x16)
Nismo fuel pump 4.1L/min
Nissan z32 AFM
Tomei ras kit
Tomei extreme exhaust manifold
Tomei N2 oil block
Greddy large alu baffled oil sump
Greddy pulley kit
Blits NUR spec r cat back exhaust
Moonface MF-R chamber pro (elboe/front pipe)
Sard ATC active torque control (replaces cat)
Samco rad pipes
Apexi power air filter
Apexi power fc with hand commander
Cusco oil catch can x2
Spitfire coilpacks
Spitfire DI bridge
Spitfire ground wire kit
Nissan z32 fuel filter
Fuch/silicone pro s 5w-40
Power enterprise super Kevlar belts set
Power flex poly-Urethane exhaust hanger
Tomei Type A valve springs
Tomei poncam type R 256deg 11.5mm lift ex/in
Supertech valve stem seals
Brain crower Ti spring retainers (BC2200)
Cosworth MLS head gasket 1.1mm
ARP 204-4204 engine head studs bolts kit
Transmission
ORC full metal clutch kit
Nismo braided clutch line
Nismo strengthened pivot
Uras imo youkan transmission mount
Motul 90PA Diff oil
Moonface magnetic plugs
ATS metal diff 2 way
Nissan 4.08:1 final drive
Cooling
Blitz LM intercooler
Trust greddy oil filter relocation and thermostat
Interior
Yashio gearknob
Bee*R steering wheel
Works bell boss kit
Headunit
Handling
Cusco type ALC OS front strut brace
Tein Monoflex coilovers 7kg/5kg
Rays engineering - Volk racing TE 37 18x9.5 et12 and 18x10.5 ET15
Ikeya formula tie rods with spacers
Megan adjustable tie rod ends
Apex performance adjustable caster rose joints
Whiteline anti rollbars
Hsardrace roll centre adjuster Nismo steering rack bush
Apex front lower brace
Parts shop max traction rod
Apex rear subframe c collars
Megan rear adjustable camber arm rose joint
Powerflex adjustable toe arm bushes
Nissan z32 alloy rear knuckes conversion
SPL - Z32 spherical rose joint for suspension lower mount
Super pro poly bushings for rear knuckles
Whiteline rear knucke poly bushings
Brakes
Motul RBF600 dot 4 brake fluid
Nissan z32 BCM
Nissan R33 calipers
Goodridge braided hoses
Nissan r33 rear brake drum assembly, backing plate, handbrake assembly, cable
Exterior
T&E carmake vertex ridge widebody kit
Bellof led side lights
Nismo smoked wing lights
Rear wiper delete
Wind deflectors
Will add more details when I get home
Thanks,
Chris
Nissan z32 AFM
Tomei ras kit
Tomei N2 oil block
Greddy pulley kit
Samco rad pipes
Spitfire coilpacks
Spitfire DI bridge
Transmission
Motul 90PA Diff oil
Cooling
Interior
Yashio gearknob
Works bell boss kit
Headunit
Handling
Brakes
Nissan z32 BCM
Nissan R33 calipers
Exterior
Rear wiper delete
Wind deflectors
Thanks,
Chris
