78 Works Headlights V2
20 August 2021
U.K
Hey,
I am looking into buying a set of V2 78 Works S15 headlights.
Currently I am just wondering if there is any guide to fitting aftermarket headlights to the S15, how to install and how to check they are the right kind of headlight.
Thanks!
15 September 2021
Yokohama, Japan
Hi,
There should not be a problem with fitting the 78 works V2 S15 headlights onto your car as long as it is a S15. The install is pretty easy with mostly plug and play. You may have to do some adjustments to align the lights afterwards but the included book should help. If you want to run HID lights remember you may need to install a ballast first. You can always contact 78works through there website if you have any questions. Yes it is in Japanese, use autotranslate on chrome or whatever browser to fill it in. They will respond usually in English if you write in English. Personally I run the V3 headlights and it was a pretty easy install.
Website: https://www.78-works.jp/
S15 Headlights: https://www.78-works.jp/shopbrand/ct58/
