ABS Issue
14 March 2021
Norway
Did a engiene swap from sr20de to a s15 sr20det with loom and ecu. ABS ecu Included.
While swapping I also changed the calipers to spec r ones.
After startup everything is working good, except that after a few meteres my ABS lamp lights up and the ABS do not work when using the brakes.
Any tips?
24 January 2013
Kent
is there an ABS sensor on the diff housing in a spec S? have you checked for continuity in the sensor wiring? Also what error codes are you getting from the ECU?
14 March 2021
Norway
Thank you for reply. I will check it out!
14 March 2021
Norway
Heya. Cant see any visible breach of the wires.
The error code is actuator relay - off.
14 March 2021
Norway
Okay, after some search I found a cable behind the front light on the passanger side. The cable goes behind the coolant reservoir. Reconnected this and problem solved 👍
