Headlight cleaning
drifter
4 April 2011
Norfolk
What are people using to clean there headlights? Never had much of an issue with the S14a as they were glass, but the S15 plastic lenses always look foggy.
Any tips would be appreciated as it's annoying me :D
I use t-cut and finish with something like super resin polish.
26 January 2011
Mayo,Ireland
I also use t-cut on mine, ive tried several polishs and compounds but found t-cut to be the best
drifter
4 April 2011
Norfolk
Cool, I'll dig out some T-Cut, should have some somewhere :) Cheers
Or if you look on eBay there are lots of plastic polishes available.
drifter
4 April 2011
Norfolk
I've ordered the Mequires kit on ebay, hopefully I'll have it by the weekend so I can post up what it's like :D
18 July 2009
Warwickshire, England
I wet sanded mine with 1500/2000 grit, then buffed up with G3, then used Renovo plastic polish.
13 July 2010
Brighton-UK
The very best way to polish your lenses is to use a rotary or DA polisher and a fine polish such as Menzerna (85ED) or 3M (Ultrafina), both with some care (so as not to burn the plastic) will give you a like new finish, but it's not really for the inexperienced, otherwise as everyone above had said you'll have to polish it by hand and probably best with a dedicated plastic polish unless you use a machine polisher, with a machine polisher you would typically use a fine paint detailing polish such as the above.
11 February 2010
Mansfield
Machine polisher, G10 with a squirt of water and a bit of patience, came up like new! Also used polish after. When i'm out of G10 i'll be using the 3M ultrafina as mentioned above, good stuff from what ive seen
13 July 2010
Brighton-UK
The 3M stuff is great, have been using Menzerna polish and Lake Country, Menzerna pads, but have now changed over the 3M polish (using all 3) and the 3M pads, the pads especialy are top draw compared to the others.
Sorry for spamming the thread :)
drifter
4 April 2011
Norfolk
Got the Meguires kit with a Plastx polish and pad etc. Worked well, easy to use, but not quite hard enough to get some of the bigger marks. Having said that all the misty patches have gone and the lights now look mega.
