High Idle - not by much though
T
Toby
This is causing me greif with the MOT man.
The car idles at 1050-1100rpm and 1050 is the top limit.
I belive the car should be closer to 900-1000.
Car has a turbo back exhuast, currently with a Decat, although I am fitting the cat this weekend, perhaps that may help the situation?
Is there anything else I should try?
Thank once again all!
R
Rasi
Try and adjust the throttle cable.. may help.
28 July 2009
Hertfordshire
Don't bother adjusting the throttle cable, just turn the idle control valve until you get the idle you want. Adjust the screw when the engine is fully warmed up.
T
Toby
All fixed my friend, fitting the cat seemed to bring it down just enough! - It was only just over anyway.
