ALL ITEMS SOLD!!!
I've been thinking about this for a while and I just don't want to rip my car to pieces because I'm thinking of selling it for something else. So, I'm going to see if there's interest in the mass amount of parts I've built up for it over the last few months. I'll see what kind of interest I receive as I'm not completely decided on what to do, but if people want parts I will most probably start selling bits.
First off the engine, the only part that is used is the cylinder head but has only been run for 3k miles and still looks like new.
Bottom end, all brand new, not even assembled
S14a block honed out for oversized pistons
Brand new 86.5mm CP 9:1 forged pistons
Brand new Eagle forged rods
Brand new ACL standard size race main bearings
Brand new ACL standard size race big end
Standard size crank with polished faces
Brand new ARP head stud kit
Brand new ARP bottem end stud kit
Brand new genuine Nissan oil pump
Brand new genuine Nissan oil strainer
Brand new genuine Nissan chain tensioner
Brand new genuine Nissan belts
Brand new genuine Nissan flywheel bolts
Complete genuine Nissan engine gasket kit
Brand new genuine Nissan thrust washers
Brand new A'pexi 1.1mm metal head gasket
Brand new ACT Heavy duty paddle clutch
Brand new ACT Ultralite flywheel
Brand new Apex alloy crank pulley
Cylinder head
Skimmed head face
3 angle valves and seats
Supertech Inconel, back cut, swirl polished valves (intake and exh)
Phosphor bronze valve guides (JW)
All new nissan seals, all threads chased etc
New Nissan rockers
Tomei Solid lifter conversion
Tomei solid 260deg cams (VVT can be used or removed) comes with VVT
Brian crower Titanium Retainers and Springs
Polished Exhaust Ports
Smoothed valve lips (In and Ex)
Smoothed (not polished) intake ports
Mirror polished combustion chamber (matched cc)
£3000 for both
GReddy short port plenum, GReddy top feed fuel rail, Injector Dynamics 1000cc injectors and 60mm throttle body. There's also an N15 throttle body adapter from Tomei I'll throw in. All parts brand new in wrapping except for throttle body. £1000
Genuine Sard fuel pressure regulator, With barbed fittings. Brand new. £120
GT3082R top mount turbo kit. I've had to get a few parts made for this and none of the exhaust parts would fit my car nor the intercooler piping, so I'll supply what I had to get made so it fits your car. Kit includes Garrett GT3082R turbo with .82 a/r exhaust housing, Full Race top mount exhaust manifold, oil feed line, water lines, oil return pipe, Tial 44mm v-band external wasetgate with screamer, top mount 4 bolt fitting down pipe that bolts to the 3 bolt front pipe, chrome intake pipe with black silicone couplers and Apexi air filter, plus I'll supply hot side pipes for the intercooler with black silicone joiners. £1500
Cylinder head
Skimmed head face
New Nissan rockers
£3000 for both
