oil catch cans ??
subzero
2 June 2007
Limerick Ireland
Recommended , good addition for the engine ??? love the look of the cusco part but wud like it to be functional as well ??
there seems to be differnet version a 9mm and a 15mm , which is correct for a spec r ??
The stock hoses are about 15mm in diameter, so that is what I would use :)
Don't leave it venting to atmosphere.
Reroute it back to the elephant trunk like the stock setup.
It's healthier for the nature and your engine. :thumbs:
24 January 2008
get the one which is specifically designed to fit the s15 rather than the universal model. it comes with the holder to fit the catch can on the top left corner. but the package only comes with one set of hose so you'll need to get another one if you're goning to route back to the intake pipe.
When you take off the generic hose from the side of your rocker cover inside it is a brass restrictor, put that back into the new venting hose.
jj-coupe
anyone know wer i could get the 1 thats specifically designed to fit the S15, the 1 thats in the pictue?
JDM JUNKIE
I like this one by Kazama... cool pic too not every day you see TT on an SR with a surge tank hun?
GUEST_JDM
letting your engine breath blow by is worse than venting to atmosphere ( for your engine that is lol not the environment)
