FS: S15 Spec R Complete engine package
21 May 2015
Chelmsford
Due to new plans with our Spec R we are going to be selling the complete engine package.
The car has covered a total of 125000kms and was on 101000kms when we bought it into the country.
Sadly due to rear end damage we are now going to be buliding the car for track use only an.d for that reason we will be going for a different engine set up.
This has been my girfreinds car and only ever used on the road and most of the time has had our children in it so very well looked after.
It will come complete so:
Engine with inlet and exhaust manifold/Turbo
Pas pump, alternator, aircon pump
Engine loom
ECU
VAG coil pack conversion( brand New Delphi Coils)
All pipework
FMIC with pipework ect
Rad with cowling and viscous fan and hoses
HKS intake hard pipe and air filter(bought new and done 15000kms)
6 Speed gearbox ( had new bearings 150miles ago) mint no crunches wines ect
driftworks DMF delete flywheel (again brand new 150 miles ago)
Excedy stage 1 clutch ( again brand new 150 miles ago)
Prop shaft
engine mounts
gearbox mount
gear lever
Turbo elbow (stock
Down pipe (stock)
You will basically get a complete conversion to drop straight into your Spec S!
Engine has been compression tested cold and hot last week and was 150psi across all cylinders, oil pressure is good, has defi's fitted so can be seen. Never ever used any oil or water and never gets hot, even through the summer with air con blasting away. Turbo boosts good, no smoke ect and no oil or water leaks at all.
Turbo gaskets was replace last year with genuine nissan gaskets and new HEL braided oil and water lines.
Seviced every year and only ever run on Fuchs oil.
Can be seen running and driving prior to removal, Compression test welcome.
I can also offer a fitting service if required.
£3500
Please we are not breaking the rest of the car so NO OTHER PARTS ARE FOR SALE!!
Imgur: The magic of the Internet
Cold compression tests
https://imgur.com/oI70x3O
https://imgur.com/2cfAHS6
https://imgur.com/bZ2dNeI
https://imgur.com/bvWtlbR
Hot tests
https://imgur.com/SxkQhJT
https://imgur.com/TYYU74N
https://imgur.com/FrgOWrs
https://imgur.com/FoOKv11
21 May 2015
Chelmsford
Pics
Sent from my SM-G950F using Tapatalk
21 May 2015
Chelmsford
More pics
