Thats why I run a modified stock BOV.
				Do it any time,just means it will hold higher then stock boost.how and when should you modify the stock bov?
I wondered what that does, is it just a bleed off hole?Do it any time,just means it will hold higher then stock boost.
Remove the blow off valve from the base, 3 screws from memory and just to the side of the diaphram you will see a small hole. Block that of with a small screw. Once I did that I cut the head of it off with a Dremel so it was flush.
Yes,thats why it wont hold higher boostI wondered what that does, is it just a bleed off hole?
bung that up good thenYes,thats why it wont hold higher boost
going out too put the factory one back on to test................It's simple but effective, and if you can use the OEM product it has to be a good thing.
*Waits for results*going out too put the factory one back on to test................
next time my friendly friend, we will hand your ass to you on a plate*Waits for results*
Bad luck about the footy Spoonman![]()
Hahaha, getting tired of eating yours, I'll send you some recipes, you must be getting sick of the same dish.(I use them when the Rugby Union is on) :wave:next time my friendly friend, we will hand your ass to you on a plate
