FS: having a clearout, lots of odd bits for sale
Stock s15 re-circ valve perfect condition, perfect working order. 20-00 delivered.
Stock s15 boost solenoid, perfect condition, perfect working order. 20-00 delivered.
SR20 s14/a power steering lightweight alloy pulley (db power). 10-00 delivered.
Standard oil cap S14/A S15 – perfect. 6-00 delivered.
Standard s15 hot pipe FITS S14/A, no dents good condition, couple of marks, ready to paint or whatever. 15-00 delivered.
Stock s15 boost gauge and map sensor, perfect condition, perfect working order – did not misbehave like some. 35-00 delivered.
S15 stock arb’s with good bushes and rear droplinks FITS S14/A. Pretty much as new, bushes arent worn, links are good with no play so can be re-used, no rust. 40-00 + postage.
s14/a/s15 upper plenum, bit dirty but should polish up perfect - mine did and that was rotten. 25-00 posted.
set of stainless lockable bonnet catches - 15-00 delivered.
all stuff can be collected from me12, pm me if interested
pics added
pulley
boost solenoid
re-circ valve
oil cap
hotpipe
s14a/s15 plenum for polishing
s15 arb's
sx-si
7 June 2008
hampshire uk
can you pm me a decent price for
S15 non aero fogs – perfect condition with trims and clips, perfect working order. 45-00 delivered
S15 rocker cover few tiny marks otherwise perfect with no broken tabs. 45-00 + postage.
New 4.5 metre roll of silver heat wrap 10-00 delivered.
and the s15 pletnum :)
pm sent:)
little bump:)
als_jordan
13 July 2007
Dean, will the bonnet lifters fit the S15?
bump on these bits :)
5 November 2008
Will the pulley be ok for the S15? Would be quite tempted.... Dont suppose you have pics fitted?
Also I guess the heat wrap has gone?
sorry mate, the pulley should say s14/a, its meant for them and when fitted to the s15 its ever so slightly off line. the rest is all s15 or compatible ;) the heat wrap is all gone....surprised no-ones had the plenum for polishing though :?
