Another coolant leak!
5 November 2008
Hertfordshire
Hi guys,
Just picked my car up from Torque and im very happy with it but its got a couple of little problems the turbo to mani gasket is now starting to go and the car has just begun to overheat! i've had a search on here and it seems common for the water lines on the turbo to go so i had a look and sure enough thats where its leaking from.
I'm hoping it'll all be covered on my warranty
so just to check this is what i need before i order them;
http://www.hosesolutions.org.uk/ind...id=794&zenid=892234cb64758d6328e6417621a456da
and
14415-8H600 is this gasket from Nissan UK because i want it sorted asap?
Cheers guys
27 April 2006
Ireland
yup those are the lines just make sure you get some new crush washers for them and youre good to go, the gasket seems to be bang on too.
27 April 2006
Ireland
your bolts should be fine to be honest id suggest just getting the same diameter copper wahsers that nissan use, you can buy them in halfords or most motorfactors i think i got a box of 150 for 2.99 or something.
