cant get full boost when car is hot
james s15
hi ppl, have an issue with my boost at the moment.
when the car is hot the boost is very weak only .5psi and.7psi after 5000rpm.
and for some reason it just feels weak. as if there is hardly any boost
I think its the actuator which is acting up. but does anyone think its down to a lack of cold air through the induction kit
I have a new manifold and induction kit onthe car, i might of damaged the actuator when i had the turbo out.
T
Toby
Standard Boost Solinoid?
james s15
Sorry I only know a little about s15's and never heard of a boost solinoid?, i probably know what it is to see it but not what its called, where would i find it on the car?
I have perfect boost and power for a few minutes when i start driving but as soon as it warms up power reduces
i seem to be getting a lot of oil spray out of the dump valve also? any ideas
im getting a lend of a mini vac during the week to see if the actuator is stuffed
does anyone know if the actuator works from vaccum or preasure?
its a right little head wrecker this one
I have just fitted a japspeed manifold and a blits sus induction, but i dont think these have anything to do with it. Oh and the release bearing is going on the clutch
Luck isnt on my side lately hahaha
any help is always welcomed and appreciated guys :)
sx-si
7 June 2008
hampshire uk
does it sound any diffrent as it might have a crack in the manifold
james s15
No I solved that problem with the gasket and new manifold, no exhaust leak anywhere :)
james s15
Think i have the problem solved, it is the turbo seals. thats why im getting oil spray out of the Blow off valve
would anyone have a different opinion?
