flush wheels front and rear s15
sx-si
7 June 2008
hampshire uk
what size and offset to get the wheels flush with stock archs?
25 February 2006
East UK
yours look pretty flush. what are they and add the difference :D
sx-si
7 June 2008
hampshire uk
nope like 3deg of camber rear and like 6deg of camber front
need to work out the sizes of front and rear fenders
sx-si
7 June 2008
hampshire uk
work equip anhelo incrediablly rare only ever seen 3 sets 2in yahoo japan and the other on zilvia.net
before you ask i wouldnt sell for less than 1700
sx-si
7 June 2008
hampshire uk
if what i think is right
front 8j et28 making my 8j et 8 stick out about 19mm
rear 9j et 40 making my 9j et 20 stick out 20mm
is that right?
got 25mm front fenders allready
need to sort the rears maybe 30mm
then get my other equips built to suit
19 June 2007
Essex / UK
My WORK XD9's 8" +30 (5mm spacer) F & 9" +38 R were the perfect fit when running whiteline touring alignment settings. Now with my CR Kais i gotta run a fair bit of camber to tuck the top of the rim within line of the arch and have sacrificed handling and driveability by doing so.
Hi mate - I've got +50mm rear arches and running 17 x 9.5J ET30 (no spacers):
I'm currently looking for 5mm spacers as there's still room for me to push out a little without rubbing. Lowered on Tein coilovers with camber at -2.5 deg.
sx-si
7 June 2008
hampshire uk
jez based on alot of maths ive done and reading the wheel thread i think your quite right there
lupix that doesnt sound right you should of only had to put on 20mm rear fenders for it to be roughly flush?
unless you got crazy backwards camber
10j et3 would sit perfectly with the rear arch without camber
sx-si
7 June 2008
hampshire uk
im confused
google says 1inch is 25.4mm
offset calculator says to keep the exterior lip-wheel the same when adding a inch to a wheel is 26.0mm?
http://www.1010tires.com/WheelOffsetCalculator.asp
"edit" ive worked it out as its rounding it up to 26mm
stock
front 8j et 28
rear 9j et 40
50mm rear fenders
10j et3
9j -10
30mm rear fenders
9j 10
10j 23
25mm front
8j 3
8.5j 9
9j 16
5 November 2008
Hertfordshire
So do you think these will fit the stock rear arches?
18 x 9.5j - ET30
18 x 9.5j - ET30
i've got these with 255/35/18 mate and run some negative camber on rolled rears - but they fit nicely
5 November 2008
Hertfordshire
Awesome.. Thanks Dean!! :thumbs:
sx-si
7 June 2008
hampshire uk
ok my final wheel spec are 8j -7 fronts with 3.5 deg front camber and rears are 10j -7 with 2 deg of rear camber
thats with 25mm front fenders and 50mm rear fenders
sx-si
7 June 2008
hampshire uk
might have made a **** up as i roughly measured my rears today and there coming out about 9j et8 not 9j et20
ill get to the bottom of this if it kills me
13 June 2010
Pisa, Italy
www.flickr.com
A 10J +42 will sit perfectly flush on the back with 0 camber. Right now I'm running 9.5J +20 on the front and it's a little bit sunken in but I'm running -3 camber, if I pushed it out to -2 it would probly be flush.
sx-si
7 June 2008
hampshire uk
you got over fenders hypnotic?
i got 50mm rears and 9j et 20 + 40mm fenders and 2.5 deg of camber is flush
back on track rears are defo 9j et 20
18 July 2009
Warwickshire, England
I've got stock arches with the lip rolled back flat, and run on 17x9 et22 with a 225/45 tyre, -3 camber. If I undo the bottom mount of the damper and jack up the wheel into the arch, I've got about 8-10mm of clearance. At a normal (lowered) height, the wheel sits flush, nudging towards slightly poked. Like this infact. The picture doesn't show it that well as its not looking directly inline with the car. Still gives you an idea though :)
13 June 2010
Pisa, Italy
www.flickr.com
Here's what I'm running at the moment.
Front 18x9.5, offset +20, 225/40-18, -3 camber, stock fender
Rear 18x9.5, offset +20, 235/40-18, 0 camber, stock fender, rolled, not pulled
