Front cover Transmission seal
15 August 2008
Ireland
Hey folks,
Looking to get as named above the part number is 32113-89F00
Stiv is doing some work on my car and noticed the gearbox leaking a drop of oil cause of the seal. He has rang the main dealers in Dublin and [FONT=&quot]Nevada, where he gets alot of bits but they have told him 6weeks.
So if anyone knows where i could locate the item would be brilliant.
also still looking for a standard bonnet if anyone has one for sale r knows where to get one.
Thanks for the help people..:notworthy::notworthy:
[/FONT]
sands
11 April 2008
kilkenny, ireland
Is this the oil seal at rear of the gear box where prop shaft sits in? mine has small leak there did you have any luck finding the seal?
15 August 2008
Ireland
My mechanic got one, had a good bit of trouble. ill give him a bell later and see where he got it.
sands
11 April 2008
kilkenny, ireland
Is that the same seal i have leaking didnt think it would be called (Front cover Transmission seal) when it's at rear of the gearbox. if it is least have part number to start whit. if you could find out be handy thanks.
Edit anyone whit fast want to help me out hear whit the part number?
15 August 2008
Ireland
Ya its a different seal alright mine was front, i read your mail to quick as i was in a rush.
Anyhow i rang my mechanic and if he thinks of it, he`ll dig out a part number for the seal your afte. If/or when he sends it on ill let ya know.
T
tripleJs15
I have a minor leak at the propeller shaft and on the shifter plate, the prop shaft leaks only if the car is raised in the front and the shifter plate leaks a couple drops when I drive.
I'm sure one of the variations of the s13/14 uses the same seal, any help would be great.
15 August 2008
Ireland
Rear Oil Seal part number
32136-89F00
T
tripleJs15
the problem is since i'm in the US that part number won't work, can you tell what other cars use that same seal ? I may be able to locate it by the car.
6 April 2009
ireland
Just for anyone with a Spec S, the part number for the 5 speed rear oil seal at the prop shaft is 32136-U0100
sands
11 April 2008
kilkenny, ireland
Have new seal on order will be while till get it doh.
Is there much to fitting this seal or will it just pull out by hand?
6 April 2009
ireland
well on my one was just drop off the prop, and prise it out with a screw driver, took an hour all the same!
