gear box and diff oil
K
kieran
ok i know this has been covered but ive done a search a cant find what im lookng for?
need to know what oils to use and how much, also when giving detailsof oils need to know what nisan recommend as well as your personal recommendations, may be we could making this a sticky in the useful threads :thumbs:
Motul gear300 75W90 for the gearbox.
Really made my gearchanges smoother. I bought 2L and filled through the gear lever inside the car. Used all 2 Liters.
Never had a problem and changes gear like a dream.
I have some Motul 90PA going in the diff. Haven't done the change yet though.
There is a new Motul diff oil which is supposed to be better out now. Can't remember the name, but I think it's in the 300 range.
Cost about twice as much as the 90PA though :(
S15R
I've used Motul Gear 300 and Motul 300V last service, i found the Gear 3000 takes longer to warm up and crunches in cold weather... now i use stock oil for gearbox and diff.
I'd recommend Motul 300V for engine oil :D
I found nissan oils more reliable and what i meant by more reliable is that they are designed for any or most weather condition. :D
black country
www.coordsport.com
i used redline oil
lightweight for the gearbox and heavy for the diff,
i cant remember how much though :confused:
think it was 2 bottles for gearbox and one and half for the diff.
Derek
i use mobil 1 ms 15w 55 for engine 4.5L
Mobil fully synthecic 85w 90 gear oil 2L
Duckhams Diff oil
Mintex Clutch and brake oil Dot 5.1
Redline Shockproof Lightweight for the gearbox (overfilled to 2.2 litres)
Redline Shockproof Heavy for the diff
Whichever fully synth 10/15W40/50 oil takes my fancy for the engine. Currently using Halfrauds Motorsport, which is a Comma oil.
sushiming
13 November 2005
Hong Kong
need to get the gear box and diff oil asap where can i get them from?? iam going for redline..
also which brake fulid i should get aswell?? please help need them b4 next wednsday
Delta Oil Ltd
Red Line Synthetic Oil European Distribution
Unit F1 Market Overton Ind Est.
Market Overton
Rutland
LE15 7PP
Tel : 01572 768311
Fax : 01572 768249
Think they may have changed name now...
Speedy
Going by the manual i have found:
Gear Oil 1.8 Liters
Rear Diff 1.2-1.4 Liters
500ml brake fluid i would of thought, completely empty the Master cylinder and top up with new fluid. Then on each caliper staring furthest from the MC about 1-2cm drop in level in the MC. Thats how i was taught at Mazda.
Hope this helps :)
No, no, no. Don't empty the BMC. If you do that, you'll land up having to bench bleed it to get the air out and potentially have air locks in the lines. Just bleed every line thoroughly and keep topping the reservoir. Let it get quite low initially, but not empty.
Speedy
I didnt mean bleed until the MC was empty, at work we had a suction pump to empty then top up then start bleeding. Im sorry if i came across the wrong way.
sushiming
13 November 2005
Hong Kong
well its all gonna be done at a garage as i got no time to do it but if they do it normally how much would i need??
Speedy
I only ever used 1 500ml bottle of brake fluid that should be more than enough and the MC looks slightly smaller than all Mazda's so id say 500ml should be plenty. As for oil id just buy 2 Litres and keep the other as spare for the next change.
