Gearbox Oil Replacement
Meddy
Last night I was starting to think about replacing my gearbox oil Ive had sat in the garage for months (Does anyone see a pattern forming here? :D ), but looking under the car I couldnt really see a way of getting the oil back into the box.
What I mean is I could see the fill plug but without the car being on a lift didnt think it would be possible to fill it. With the Diff I just ran a section of hose and poured the oil in through gravity, but Im not sure this will work with the box as its quite a climb uphill from the cars underbody to the fill hole.
Anyway enough rambling ideas and the way you did it please.
Thanks.
Like you say, diff oil is reasonable easy (except getting the plugs out :p ):
I did the gearbox oil from the top. Took out the gearbox boots and cover and just pour it in. However, after putting the gearbox cover back on, I wished I'dd tried the hose method. :p The two bolts on the engine side are a right bastard to get to (as in, underneath is the only way). Filling is piss easy though. Also allows the overfill that I've mentioned before.
Meddy
Sorry to resurrect this thread but finally got my lazy ass into gear and drained my gearbox oil. :rolleyes: Glad Nissan got rid of the plugs and used bolts on the S15. :nod: Now next question Nicely you say you struggled with the cover plate on the box but does this have to come off, or can I just remove the gearshift with this in place as Ive seen suggested on SXOC? Id have a look in the manual myself but unfortunately its packed away ready for moving house. I may run a hose through the engine bay I cant decide. :rolleyes: Will sort refilling tomorrow. :nod:
Thanks for any help.
I also have new gearbox oil aiting in the garage :)
Would like to use the filler hole to fill it up again. But where is it??
Looked at my photos. It may be possible to fill by removing the gearshift. Didn't try it though...
As for the fill hole. Bottom plug is the drain, top one the fill plug. Not easy...
Meddy
Ok I did it. I just undid the four bolts holding on the gearstick and mount, removed the two easy ones and the front right twisted the mount out of the way and filled it. I used a ratcheting ring spanner and found I could get the two front bolts easily from inside the car. :nod:
Front two are easy :nod:
Did you try just taking the gear shift out?
Meddy
By front I mean the two towards the engine/front of the car which you cant just drop a socket on.
I had a look at taking the gearstick out but its not as easy a job as on the 14's :( There are 2 rubber seals, the second of which I decided I would probably run the risk of tearing to remove. The workshop manual says to just cut them off to remove them.
Undoing the four mounting bolts was much easier. :nod:
So you just removed the steel flange looking thing with four bolts on it and filled it up from inside the car??
The centre console (the bit with the card holder and everything) is easy to remove (4 screws and 2 cables after removing stereo sorround piece)
Would removing that make the oil change a piece of cake????
Meddy
You have to take the console out so you can remove the cover, sound deadening, coverplate and then unbolt the gearstick mount, which is where you encounter the awkward bolts. Buy a ratcheting 12mm spanner and its easy from inside the car. :nod:
I've got all my photos on the memory stick ready to write up the 'how to' for this. I'll mention using the ratchetting spanner. :nod:
OK. I was thinking of the cover plate then.
Don't know what a ratcheting spanner is. But I may have one in the garage anyway :)
Will try this instead of messing about under the car :)
Meddy
Have a look at this.
http://www.halfords.com/webapp/wcs/...mb=33958-33943&varient=&CarSelectorCatalogId=
Changed gearbox oil tonight.
I actually turned down partying for this :) Well that and money shortage :(
Man, gearbox-oil smells really bad :hurl:
Discovered a tiny leak from the oil filter relocation kit (1 drop/hour) so need to retighten one hose-clamp :(
How easy hard was it??
1 = Easy
10 = Hard
With a ratchetted spanner, 3. The difficult part is getting the drain plug out. You need a breaker bar, no questions. You also need some long cable ties to secure all the gearshift boots back in place.
Same with the diff oil. That's just a pain having to do the 'hose fill'.
It was pretty easy after figuring out what tools to use. Didn't have a ratcheting spanner like the one in the links before but I managed to build a similar tool from the 150 piece Kamaza tool-set :thumbs:
Was going to do a how-to guide but forgot to take pics :(
I'll see if I feel up to dismantling the whole thing again for some pics.
