GReddy oil filter relocation kit leaking..
30 June 2016
Birmingham
Anybody had there's leaking. Was thinking of taking it apart and applying some PTFE tape on the threads but it doesn't seam to be leaking from there but more like the blue anodised male connectors seal.
Anybody shed some light on this? Thanks
It shouldn't be, I have this kit and it seals really well, just check you hoses because its easy to crimp the "O" ring seals when fitting the connections
30 June 2016
Birmingham
I've brought the car with it on and I've had a look, tightened it up a little more and it's leaking tiny amounts now but I'm tempted to get some more connectors
Worth taking them off and checking the seals aren't crimped or damaged...
30 June 2016
Birmingham
Took them off for all who where wondering. Earls fittings had stripped on removal so had no alternative than to re tap/thread file them till they went in correctly and smoothly along with wrapping all the threads in PTFE tape and a new seal on the oil filter housing it's self. All good now. Thanks
Cess
Instagram Staff
10 February 2013
Northern Ireland
Mate, where did you buy this? Thinking of one for my car as it would make life handier
30 June 2016
Birmingham
Came on the car when I brought it sorry can't help ahah
4 August 2011
Be careful what filter you use with this kit as the standard ones can blow off!!!
Found that out, was told it was the stock S15 filter, Z445, turned out it was for the S13 filter, the Z442
4 August 2011
Happy days S13 or mid 80's corolla work well from memory :)
30 June 2016
Birmingham
I use a Alfa 164 oil filter from euro car parts. £2.50 and it's a direct fit. So cheap I've brought a stock up ahaha
