Hello from southern Ireland!
25 September 2011
Wexford Ireland
oh brilliant thanks.. That would be much easier and cheaper to come by! theres a lot of s14s being broke for parts in Wexford!
Have you fitted yours? If so whats it like?
dannyc6
well I have a shimmed one out of a 14 so its very tight putting another standard s14 lsd in soon I'd say some of them are better than others depends what kind of life they've had I suppose just keep an eye on the ratios the jap diffs have a shorter gear in them faster take off but lower top end they can be picked up very cheaply too!
25 September 2011
Wexford Ireland
what about the abs sensor? and what did you change? prop shafts with the new diff?
dannyc6
the abs sensor plugs in to the 14 diff same as 15 just changed propshaft (from box to diff lets say!) and diff nothing else it all bolts in driveshafts sit straight in too!
25 September 2011
Wexford Ireland
Excellent! Thanks for the advice! Think ill be going down that road after all!
dannyc6
no problem just ask if any other questions come up!!
DarioG
28 November 2007
Ireland
In reply to your question,
Yeh I actually carried out this upgrade myself back some time ago.
And it was a straight swap. If your going for it, Just make sure the inner shafts come with the Spec R differential.
There is 6 bolts on each half shaft. There was no messing about with shafts.
As long as the differential you buy is complete with the two inner shafts.
It should be no problem and it will bolt straight up to your own outer half shafts.
25 September 2011
Wexford Ireland
Thanks for the info mate! will just depends on whether a Spec R or S14 diff pop up first!
You'll probably hear from me again if it is an R diff I get!
25 September 2011
Wexford Ireland
Spec s just have an open diff only one wheel will spin , s14 has an LSD, viscous I think!
I changed the diff head in my old Spec S to a HLSD from a Spec R, worked rather well and was a cheap LSD upgrade, i just wanted to do two wheel skids....:)
25 September 2011
Wexford Ireland
Snap! That's exactly what I'm after, will hopefully be getting a Viscous LSD from an s14 soon!
