Hks ssqv
9 January 2009
Helston, Cornwall
I have brought the HKS SSQV and want to fit it but it looks like I need to move the fuse box out the way and it doesn't say any way to do it, if I undo the bolts will it simply lift out of the way? And so I really need to unplug the negative battery terminal?
9 January 2009
Helston, Cornwall
Cool, seems like a tight spot to work in without moving the fuse box out of the way!!! Especially with my sausage digits!!
tooley
When only sideways will do!
10 October 2009
West Midlands / South Wales
Its easy man dont need to move the fuse box. You can remove the battery for easier access though if you wish.
20 June 2014
Merseyside
Same as Tooley says above. I'd remove the battery, it'll be a piece of cake with that bit of extra room.
9 January 2009
Helston, Cornwall
Did it without removing the battery, sacrificed skin with my sausage digits flapping about in a small space of room. It's got a really nice sound to it as well, big fan!
9 January 2009
Helston, Cornwall
Had to use the S14 fixing mount though as it gave a better placement then the straight s15 mount, other than that it's all good and working a dream!!
20 June 2014
Merseyside
Good stuff! I nearly bought one a while back just just removed my standard one instead.
