My two babys
5 January 2007
Ballymena N.I.
have u any arch mods on for them sizes i like them rims!!
Ok, Im 99% sure although its not totally clear on the back of the wheels.
The fronts are 18x8.5 et 35 with Eibach 10mm spacers
And the rears are 18x9.5 et 21 with no spacers..
Martin.
My front are 17x8j ET35 with a 5mm spacer fitted to clear the coilover, they are on the limit as far as arch clearance is concerned, your 8.5j's with ET 25 must stick out, unless your running alot of camber?
I know wobbits S15 has 9.5j ET 45 i think, with a 10mm spacer (ET35), his arches are rolled and pulled to give more clearance, again you must run a fair bit of camber.
Do you know the camber settings?
Camber, widths and offsets seem to be different on every S15, which means we have no definative answer as to what will fit and what will not.
I think the amount of camber people are running needs to be clarified in these posts with wheel sizes and offsets. :nod:
25 January 2007
Middlesex UK
www.littleknocks.co.uk
My car was set up at Power station and i've miss placed the print out, but im not really running much camber at all. The front is straight, and on the back there is hardley any.
mint
18 March 2007
Asakusa, Tokyo
www.JDMtas.com
lovly. seen your feature in Banzai an thought .. hmmm i want one. Now im Here! LOL!
