pidgeon mod boost problem
miller81
has anyone had any problems after blocking off the standard dump valve i.e pidgeon mod???i tried it just to see what its like and noticed boost seem to fluctuate(think thats the correct spelling:))and a few pops from the exhaust from overfueling i presume???
japmadlad
28 June 2007
Armagh, N.Ireland
Yea you will find that it does over fuel a little as the AFM will be throwing in fuel thinking that there will be extra air from the recirc which is now blocked. I would recommend that you remove your cat from your exhaust to unless you want to see a cool fireworks show behind you when the popping burns it out ( does look awesome though :cool: )
Only way to keep the pidgeon and not have this issue is to get a minor adjustment to the car's map
