for sale i have a brand new in the box revotec fan controller for the sr 32mm fitment, ideal for someone that wants to lose the viscous fan and cowl.
the specs are below:
Gives direct and rapid response to water temperature, Latest surface mount sensor with no mechanical parts to wear or fail.Overcomes all the problems associated with capillary action and clip on devices.With No leaks.Instant response,Temperature Control range 70-120° C. Continuous Adjustment of Temperature by variable control in housing. Supply Voltage 12v Negative Earth Housing Material: Aluminium Space in Hose Approx : 25mm Overal Length Approx: 65mm Relay Rating: 30 AMPS Wire Lengths 700mm Supplied With:2 x Hose Clamps, Relay, Cap, 3 x Cable Ties, 1 x Self Tapping Screw, Fitting Instructions Variable Temperature Range.
45.00 delivered
(within uk)
45.00 delivered
