WTB: s15 bits
kipkerry
I have found the tension bracket supports, i won't need this anymore...
the parts that i still need:
-radiator shroud
-plastic strip under the radiator.
kipkerry
also calles "tension rod bracket""
now one that could help me ;)
sx-si
7 June 2008
hampshire uk
there the same as s14 or s14a ones dude you can pick them up really cheap on sxoc
just pm sombody breaking a car and tell them that
28 July 2009
Hertfordshire
They S14 ones fit on fine, but the S15 ones have plates welded to the bottom of them for rigidity. Not too sure how much difference it makes really.
kipkerry
Hi ,
I have found the parts and installed them already on the car....
i Need a radiator shroud for the s15 sr20det... the plastic compartment around the radiator...someone can help me???
and under the radiator there is plastic strip which rests on the radiator core support.
i need these 2 parts...
greetings
kipkerry
Also need a used coiloverkit. only front shocks is fine, but if it's a set i can buy the set.
