Hello all,
This is my first post in the forum.
Nissan Silvia S15 Spec R imported from Japan.
The project included the following mods:
Engine/ECU:
- JUN programmed ECU
- HKS EVC Boost Controller
- TRUST Blow-Off valve
- TRUST Front-mount Intercooler
- TRUST Full 80mm s/s Exhaust (turbo outlet, downpipe, exhaust)
Body Kit:
- NISSAN Silvia Aero Bodykit (front/rear/side) with extra intakes (JUN Auto)
- C-West Headlight covers
Transmission:
- NISSAN Silvia S15 Spec S 5-speed manual gearbox - (The difference in the S15 Spec R was the 6-speed manual gearbox and a helical limited slip differential. The 6-speed gearbox used the same housing as the previous Silvia S14A, but with the addition of an extra gear. This had to be done by making the other gears thinner and as a result, the 6-speed gearbox could not handle the torque on modified Silvias. So a very popular mod in Japan was the swap of the 6-speed box with the 5-speed)
- Nismo / Exedy Sports Clutch
Chassis:
- 17" Yokohama ADVANs AVS Model 5 in bronze / with Yokohama ADVAN Neovas AD07 (225FR - 245 R)
- Cusco camber arms
- Cusco Anti-Roll bar
- Cusco adjustable suspension with top mounts
Engine/ECU:
Body Kit:
Transmission:
Chassis:
- Cusco camber arms
