- 28 June 2007
- Age
- 38
- Armagh, N.Ireland
Hi guys :wave:
Been a while since I posted on here. Been doing a few bits to the car. No longer standard like when I got it. I'll post up pics & spec soon.
I'm having a slight issue with boost creep. I say slight when really I should say major. I am running a GT2871R turbo with a full 3" straight through exhaust from the turbo back. the problem is that I can't control the boost at all. Even with the actuator arm off and the wastegate half open I am boosting off the clock when I shouldn't be getting any boost at all. I stop @ 1.5bar only because I lift my foot but if I keep it on I'm sure it will just keep rising. We reckon that the wastegate is unable to dump the gases quickly enough & just keeps spooling the turbo. Thinking of porting the wastegate a couple of mm. Some lads reckon the exhaust is too free flowing & causing the problem. I've also been told that porting the wastegate may help but not elimate the problem. Other option is a bung in the exhaust to create back pressure but kind of seems like a backwards step. Will defo port the wastegate & probably get the bung for now as i've been told both together should sort the problem but anyone got any other ideas?
cheers lads :thumbs:
