squeaking
24 January 2013
Kent
been driving my car a lot recently now the weather has improved however when driving it sounds like i have sooty and sweep in the car! squeaking over bumps is horrendous. I was wondering if it is bushes that are starting to deteriorate?
I have apexi limo coil overs 4/3 spring rates and stock arms and bushes currently. car is lowered about 30mm
20 December 2016
Berkshire
Is it clear whether it’s coming from the front or back?
24 January 2013
Kent
Tbh it sounds like it’s coming from everywhere! Read that I should jack up each corner then jack the wheels up and down and see what I can find. Just wonders if anyone else has had a similar issue
20 December 2016
Berkshire
Oh right. That could be a good way to find out what’s causing it to be honest.
I know poly bushes can squeak but you don’t have them. If it was any bush I’d be inclined to think it’s a lower arm bush since it gets the most abuse. If it was subframe bushes then I would have thought it would clonk or knock, not squeak.
24 January 2013
Kent
Also read it could be a top mount seat but can’t see all 4 squeaking lol
20 December 2016
Berkshire
No, that would be a horrendous coincidence haha
Joeh
12 December 2006
London
www.silivaoc.com
@silviaownersclub
I had squeaking coming from my ARB bushes, a bit of spray grease and they were fine
What type of top mounts do you have on your coilovers ?
