What power do you think my car will make?
Curryzz
10 August 2009
Hampshire
Hi guys, I found out the news today my bottom end defiantly went so once that's fixed and run in I will be fitting a stand alone link ecu, i'l list the engine mods so you guys can see what you think...
HKS exhaust
Decat pipe
Apexi air filter
Walbro fuel pump
Split fire coil packs
Hks dump valve
Apexi type 1 intercooler
Like a idea of what power to aim for!
Paul
3 June 2008
Portsmouth/Southampton
with all those mods, you should be able to get remapped to 1.2bar and hit around 320bhp....
Curryzz
10 August 2009
Hampshire
I'd be happy with that, nice amount of useable power:)
Curryzz
10 August 2009
Hampshire
who's mapping it?
Well the company fixing and fitting the ecu is Pro Performance International but they use a mapper who is mobile who will road map it called Martin, untill later taking it to marlin engineering in Milton Keynes where it will be rolling roaded to a final map, Once it's run in with the new bottom end
sx-si
7 June 2008
hampshire uk
dont know of this guy but ive a few friends in mk and they go over to birminghamp for gregs maps
as i dont know him or what boost your going to run im going for 280-295
i think is greg gets his hands on it then 290-310
Curryzz
10 August 2009
Hampshire
Thanks bud, Adam at the garage(not the mapper) said around 300 bhp, so I think il be there or just under depending on the boost, I think it shall feel alot beter with the timing nd bits adjusted,I currently run a crappy boost valve, so iv been told the ecu will have a boost contoller built in I think he said and also I run a non reserc dump valve(hks) it makes it a bit juddery but with the new ecu it will stop all that and run smooth, correct me if I'm wrong
Curryzz
10 August 2009
Hampshire
Any recommended ones to get?Not to pricey it there is such a thing
28 July 2009
Hertfordshire
Get the NGK Iridium grade 7 plugs - I forget the exact model name, but go a search on SXOC and they will come up as it's what a lot of people use.
You will 100% need colder plugs if you are touching the boost, don't touch the boost without changing them.
I've also heard good things about Greg sound bloke as well, you can find his website here http://protuner.koalacom.co.uk/
It was a choice between Greg and Steve (FC Tuning) for me, but I've gone with Steve now. Actually going down tomorrow to get mine mapped :D
Do you mean Greg who used to work for Weston Performance? If so he is a top lad and knows his stuff.
Yeah that's the guy, the link I posted up is his own company, as he has setup on his own now..
Greg (Protuner) has done or still does the Driftworks cars. Him and Steve are the only people I've been recommended for remaps :thumbs:
Curryzz
10 August 2009
Hampshire
ok guys i'll make a note of this, its got to be done right, im a little worried the turbo might give up with high boost after its already done 80km, we will see
Mine's still strong and I've checked the shaft - no play apart from what's expected as the norm... my car's done 100k miles :wack: :)
If anything it's the actuator like mine which is getting old and tired so not holding boost at the top...
5 October 2009
The injectors and AFM will give up before the turbo:thumbs:
i made 308 hp on 1.2 bar but my injectors were being worked to hard so he lowered the boost a little to around 1.1 bar this gave me 303hp and that what im running daily.
