What to do with a cat. ( a bit of a laugh )
I found this on nissansilvia.com and thought i was rather good.
These guys were discussing about what you do when your cat collapses get a highflow or hollow it out, then one classic came up with the following.
rowstar, on 18 February 2010 - 11:11 AM, said:
Good or bad is not the issue here, the issue is if you can do it effectively.
Firstly your fist is like the size of it's head... So this would at first seem to be quite easy, but cats are quite resilient.
I'm only guessing here but i'd say one quick punch to stun it, then maybe follow with a series of smaller jabs.
good luck.
rowstar, on 18 February 2010 - 11:11 AM, said:Good or bad is not the issue here, the issue is if you can do it effectively.
good luck.
