Wheel fitment
6 June 2010
Midlands
Can anyone tell me if these wheels will fit my s15 spec r please!
Work emotion cr Kai
17/8 et +42 fronts
17/9 et +44 rears
Hub centres 73.3 mm
Thanks
2 August 2008
Finland, Nokia
www.dnsf.org
I can upload pics for you after I get home from work. I had Cr Kais in bronze and same specs as above...
I can say that with those specs, wheels are deep in the arches. But let the pictures speaks later :)
You'll probably need 25mm spacers or similar F+R
Trial_S15
13 July 2008
Meath, Ireland
www.modifiedmotors.ie
I was thinking the same. I had the same wheel sizes with ET32 fronts & ET30 rears and I had very little space to the front coilovers (less than 2-4mm) but had about 10-15mm going spare at the rear.... The DW CS2's are meant to give better than standard clearance for wheels too over other coilovers as they are inversly mounted....
I did have the stretch the tyres a bit though to get them to fit under the standard arches...
Edit;
Spec S S15
Spacers: none
Suspension: Driftworks CS2's
Comments: standard arches
Wheels: Work CR Kai
Size: 17x8JJ ET 32 Front and 17x9JJ Rears ET 30
Tyres: Hankook Ventus 215/45r17 front and 225/45r17 rear
Did you check out the Wheel fitment guide?
http://forum.s15oc.com/showthread.php?556-Ultimate-wheel-fitting-guide/page28
2 August 2008
Finland, Nokia
www.dnsf.org
Well here is my old setup. Pics are pretty weak and don't show how much wheels are hidden in arches.
Work Cr Kai
17x8 +42mm
17x9 +44mm
